Hydroboost braking system. TBP?
PGreenlawMD
New Bern
1967 with drum brakes power booster and time to convert to disc brakes all around. Wife not happy with occ grabbing of drum brakes and with 8 year old twins in the car needs to be as safe as possible. I use TBP for most parts sourcing but have spread orders to BC, graveyard, WH with equal success for specific parts and applications. Hydroboost is not universally available from all the EB vendors. Why? I know it adds significant cost IMO fr this conversion and is it worth it? I know you can’t put a price on safety, so I am gong to have this conversion professionally done. For a full conversion is it worth the extra cost upfront for the hydroboost upgrade (if it is an upgrade?)
Green_Bastard
All depends on how much money you want to put into it. You mentioned the drums grabbing. What exactly does it do? Pull to one side? What tire size are you running?
Skiddy
may want to just try the discs first and see how it does. also depending on what tire size your running
fordguy
the disc will fix the pulling problems. remember when mine was running and a mild built engine, whoa and go were both an adventure with front drums. could not keep it straight with either lol.
Local Boy
Mililani, Hawaii
IMHO: Front disc's are really quite robust... If your ride is mostly stock or mildly modified with 33's or smaller tires... These will do the job well...
Hydroboost becomes more of a necessity when running high power motors (think fast = speed) and large tires (think rolling mass = weight) ...
Either way...it will be a huge improvement to front drums...
Aloha
P
PGreenlawMD
New Bern
Tires are 32x11.5 15 inch rims
Nothing crazy with 351 factory 3 speed geared low. I won’t win any races but do want to be able to stop for those unexpected red lights without feeling like I am wrestling the front end to stay in my lane,,,
P
PGreenlawMD
New Bern
Thanks for all the input. Will probably go with power disc brake setup from TBP and hold off on hydro boost for now. Just curious on input why vendors carry hydroboost and others don’t. Different beliefs in what is needed for supply and demand in the brake market.
bosshoff
I have 4 wheel Disc Hydroboost on my 73
Ok, my truck is a mess, but it is my mess. I have a 302, and after the 4 wheel drums pulled so violently to the right during a panic stop that I nearly hit the car in the lane next to me, I called my good friend John (72_EB) to do my conversion. I had accumulated a box of parts, stainless braided hoses, Saginaw dual return pump, fittings, brackets, Caddy rear calipers, pads, etc, etc., etc. John came through like a champ and found an EBay bracket to make things easier on him. This is the BEST $ I have spent on my rig. If I was doing this on a nice rig, not my sentimental piece of crap I call the White Devil, I would look into Wilwood fancy disk front brakes, and keep the rear drum brakes. I would buy the complete Hydroboost “kit” from a vendor. I probably had more money in my cobbled together solution that just a kit, but I got it one piece at a time, and it didn’t cost me a dime, you’ll know it’s me when I come through your town. I’m gonna ride around in style and gonna drive everybody wild.
hyghlndr
Hockessin, Delaware
For the hydroboost you're better off searching eBay for the fittings and bracket then look for a Chevy astro booster and connect to a Dodge diplomat master cylinder, whole lot cheaper and well proven.
toddz69
I imagine your second sentence pretty well sums it up. Or maybe they didn't think they would sell very many when vendors approached them. Duffs sold a hydroboost kit for a few years and then dropped it.
I helped develop the kit sold by WH and Jeff's and I provided the names of all the various vendors to the manufacturer when it came time to try and sell them.
Todd Z.
Toque4
Richmond, BC
Kit source
Todd, you said you helped develop hydro kits for WH & Jeff’s. Do you have a recommendation for one of those sources that provides a better complete kit; all the parts including m/c, hoses and fittings and fits well in an EB with a 5.0 EFI? Thanks.
toddz69
I don't have a recommendation with regards to a complete kit with all the hoses, fittings, etc. I believe the vendors spec most of those pieces themselves.
Todd Z.
KyddsPly
I was happy with the disk conversation in all the corners with a vacuum booster. But once I crossed the 35 marker, it just wasn’t working. Now I’m on 37’s and running the WH hydro and couldn’t be happier.
Sent from my iPhone using Tapatalk Pro
gray gables
this is a great post, exactly what I needed. My 67 has drums all around that work fine, stock height and stock tires. I did do a dual shock kit on the front which helped alot with the nose diving during braking. But I plan on doing discs in the front this spring. I'm going with the kit on ebay from Horsepower sales.
