Hydroboost Dual Return Power Steering Pumps
FoMoCoBronCo
I've been researching dual return pumps for my hydroboost setup, and it appears that most recommendations are either for the Cardone 96-8739 or the Cardone 50-6002 (Old P/N 20-8696).
I'm assuming the only difference between the 2 is where the low pressure returns are located and in which direction they exit the pump.
Has anyone had experience with one or both of these and can make a reccomendation based on which style is easier to attach to?
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Doesn't matter. Run what fits best. You can use a "T" fitting to a single reservoir too as long as the T is close to pump you shouldn't have any issues.
