Hydroboost fittings
Im doing the 1997 F350 hydro boost and having a tough time with the fittings. I using 8-an hose fittings but I cant seem to figure out the adaptor fitting on the HB. Im not familiar with them. Can someone help me out? Thanks Ben
EPB72
Pleasant Hill, CA
https://www.ebay.com/itm/2854375744...d=link&campid=5335857059&toolid=20001&mkevt=1 heres an example for 6an 3/8 hose ...Why 8an 1/2 hose ,,only get steel fittings no aluminum,, wildhorses has the fittings , PSC , google hydroboost adaptor fittings they will pop up,,,, i;ve never seen local parts houses have them possible a local hydrolic line and tube may, the sizes are the link i provided , you are talking about a astrovan HB ,,
Idaho Ben
ntsqd
heratic car camper
Upper SoKA
Why -8? Most PS systems will work fine on -6, but there are instances where -8 is called for. You'll have a lot easier time finding the adapters for -6.
Idaho Ben
Because I already had lions made, and they used 8 I didn’t know any different so I went with what they recommended.
Idaho Ben
I’ve read the smaller one is 5/8 and then I’ve read it at 16 mm on the super duty Hydro boost. Does anybody know?
ntsqd
heratic car camper
Upper SoKA
16mm and 18mm are what the two fittings that I have waiting to go into a CUCV H-B unit measure. They are std. late GM PS box and pump "O-ring Bump" steel adapter fittings. The same fittings are what I have in the Vanco supplied H-B unit on Snowball and the Junkyard supplied Chevy Express Van H-B unit on the Wagon. Can find the adapter fittings in aluminum, but I don't use aluminum fittings on high pressure PS lines.
toddz69
The fittings in the hydroboost are 16mm x 1.5 and 18mm x 1.5 o-ring bump- as @ntsqd notes above. The adapters are available at a zillion different places.
Todd Z.
