Can anyone tell me approximately how much fluid a wh moab hydro boost system with a cooler should take? I'm bleeding mine now and have used about 1 1/4 quarts so far. Just trying to get an idea if I'm close. Thanks yall!
Depends on what else you have plumbed into your power steering system. Mine holds a bit over 2 quarts, but I also have a PSC remote reservoir pump and ram assist.
Thanks that at least gives me something to compare to. Im simply running a saginaw pump and cooler. No ram or remote. I imagine I might be about full at 1.5 qts
Well I've been cycling the steering back and forth plus pumping the brakes for several weeks now. I haven't seen any bubbles in a while. Do yall think 1.5 qts was enough to fill it?
