But plumbing the entire set up for $50? Good luck doing another one that cheap. WH's sells 2 fittings w/3' of hose for $45. That's a better deal than my local supply house. That type of hose is Air/Brake hose for big trucks. It's $7 a ft. and the reusable fittings are now $20 ea. I used 7' of hose and four fittings for my two HP hoses. $130. Still need to plumb the low pressure side. I'm not bitching about the cost. Just be realistic about what your going to spend. These types of hoses will last about forever if they're not rubbing on anything. And being able to make corrects lengths is a plus. The reason I posted WH's link in post #2 is because that's (IMO) the best type of hose and fittings to use, and WH's offering these parts, makes it's simple to purchase the correct stuff.
I spent $450 to plumb my entire hydro boost conversion. A cheap cooler, male AN fittings for the Hydroboost, pump and steering box. HP hose, reusable AN fittings, low pressure hose, a Tee, hose clamps, and brake line tubing and fittings. Oh, I almost forgot about the $45 adjustable proportioning valve for the rear brakes. It works awesome, one of the best mods I have done. Worth every penny. Makes it so nice to drive. Just be prepared to spend a bit of money to make it right.
Mark
