Hydroboost lines
ruckin69
Is there a kit to set up lines or did you guys have someone bend customs to fit. A mechanic I was asking to do it said there was a kit at Jc Whitney and to custom bend them is a days worth of labor. I have the hydo/master/bracket/ebay conversion setup and existing lines to the brakes from the old set up but now need to hook it up. Suggestion?
garberz
Bronco Influencer
Conejo Valley, Ca.
I bought a couple 5' sticks of 3/16" tubing at Napa, and made them myself. You'll need a tubing bender and a double flaring tool. I have the same hydro boost set up as you.
GrillMaster
What about flex from, body, frame, motor etc? add flex lines, coils, etc.? I am about to do this project myself.
You going to Bronctoberfest Garberz?
garberz
Bronco Influencer
Conejo Valley, Ca.
It put a couple loops in both brake lines for flexing.
I'm not making Bronctoberfest this year, Skip and I are doing the Dusy/Ershim trail the week before, and I'm certain I can't afford to do both.
70_Steve
Old Guy
Suggestion?
My suggestion is to kick your mechanic where it will make the biggest impression!
I bought the Metric to #6 (3/8") fittings on-line from Tallon Hydraulics, and had a local hydraulic shop make up the hoses for me. I have about $30 invested in the Metric conversion fittings and $80 in three hoses.
Both Tallon Hydraulics and Hydratech Braking Systems will carry the metric fittings, and #6 hose and fittings so you can make your own hoses.
markperry
I used the stock HP line from the SAG pump to the HBOOST off a 1993 astro van. From the HBOOST to the PS box I used the stock Bronco HP line with the assistance of a compression fitting. The Astro van line cost me 25.00 and the compression fitting was 10.00:cool:
Oh I forgot to mention, I used a propane torch to bend the metal part of the lines to make them work!
broncosam
I'd be interested in the line kit from PSC as well. Is there a part number on it ?
BUCKNBRONK
fresno
Your body to frame should not be flexing much, its the frame to axles that reqires flex lines. A couple of loops just before u hook up to the master is all u need or a peice of hose like u have is plenty. Convert your ps stuff to JIC and make your own lines with reusable hydro fittings, if u ever bust a line they are easy to fix on the trail as long as u have a spare length of hose. I went to Parker Hose they had all but one of the jic adapters in stock.
