zerostar2410
- May 19, 2009
- 610
I’m finally getting some rear disc brakes. Only problem is I’m not sure what master cylinder to go with. I used the search function and only found suggestions for the corvette master. I don’t like the look and inability to see fluid inside. I currently have hydroboost from a 95 Astro Van and use the 95 master cylinder that was with it. I like the clear plastic and leak free design but it’s only used for disc/drum applications.
Is there any master cylinders out there that will fit my 94-95 Astro van hydroboost unit with the clear plastic design?
Do I even need a new master cylinder or can I use the disc/drum one that I currently have?
