Hydroboost/Ram Assist ?
ucbronco
Summerfield, FL
To those that have Hydroboost brakes and Hydro asst steering what have you done to increase your fluid capacity and cooling? I've added hydroboost to my Bronco about a year ago and have had Hydro asst steering for 6 years, I'm having problems with steering asst fade when wheeling with the front locker working. I currently run the hd saginaw steering pump with the West Texas kit installed to help with pressure. My thoughts are capping the top of the pump and tapping in a fitting and adding an aux holding tank that will hold more fluid and keep the pump submerged in fluid. I,ve always thought more fluid capacity is a better way to go than just a cooler. If the extra capacity doesn't work I can always add a cooler later. Has anyone done this and do you have any pics of setups some of you have tried? Any input would be greatly appreciated
Thanks Butch
Tyla's toy
Martha's vineyard
I bought the wild horses extra capacity kit. Just came in today but justin and Paul were a huge help I think Paul goes by dirtdonk on here. The quality looks sweet!
ucbronco
ucbronco
Summerfield, FL
I've never heard of porting the Hydrboost. How do you do that? I was thinking it was a heat issue but I hadn't even thought about it being a flow issue.
Butch
Kyle.malone
Norman, OK
Some hydroboost units actually decrease flow when you hit the brakes.. Mine did and it was like trying to steer manual steering in the rocks.. The art of porting is not something you can do yourself. Give Van at Vanco a call and send him your unit. He will port it so that when you hit your brakes it does not decrease any flow. he will also completely rebuild it when he does it.
I am full hydro and (ported by Vanco) hydroboost and have no problems steering in the rocks on 40's.
mavereq
Vanco supposedly ports hb units if you send it to them. I'm going to send mine in. I'm convrting my pump to remote reservoir and build a full gallon Rez with multiple return ports.
chuzie
Speaking of porting and flow, does anyone know how to mod the Explorer pump to increase flow? My system has been falling on it's face. I would send it to Lee's but I heard all they do is remove a restriction in the port. If it is that easy, is it something I can do myself?
Sorry to hijack, but it seemed like the perfect thread.
Kyle.malone
Norman, OK
Chuzie... I just upgraded to the PSC pump on the explorer serp setup. I know of two others that hadto switch to the same pump as well.
allenfahey
I did this as well and have ram assist. When I wheeled in Moab I didn;t have any steering issues with 42's. My pump is from AGR and I use a trans cooler in front of the radiator.
Mountain Ram
Recovering Masshole
Abingdon, VA
I had a PSC pump on my full hydro system and blew the pump right before a big ride. I called PSC and they told me the pump was the same as an auto parts store pump, but the valve was different. I bought on from autozone, swapped the valves and have had no issue since. It's been a while, but there was someone selling the higher flow valve.
