hydroboost source
rylsky
Southern CA/NV
WCB are some good guys. Give Don a call and he can answer all the q's. They helped Vanco develop their unit and know their stuff.
mtfit
pa
Hydroboost threads everywhere, you guys must like aggravation. I have the WH hydroboost set-up and its great, why wouldnt you buy that set-up which is bolt on for broncos?
swa0330
Portland,OR
Not everyone wants to spend or has $700 + to buy that setup. I bought the same exact unit that they sell for $445 for $15.46 about a week and a half ago at a junkyard. I figure $40 on a master cylinder and and another $100 on hoses and fittings and my savings of over $600 can buy me something else. Now back to your question, that is a great price if you just want to bolt it in. The only thing to make sure is what the MC is meant for (disc/drum) or (disc/disc). That can have an effect on plunge depth.
Mark
Bronco Klutz
NW Indiana
RFR2212 said:
Around chicago the junk yards last time i went to them weren't the best.
I saw this on ebay tonight:
http://cgi.ebay.com/ebaymotors/Earl...ewItemQQcategoryZ33566QQitemZ8026113483QQrdZ1
Not sure if these are anygood, but what do you all think? I've got no idea but saw it and thought I'd throw it out to the EB forum
I don't see an external accumulator.
I'll refer to this post about the drawbacks of an internal accumulator
http://www.classicbroncos.com/forums/showpost.php?p=666227&postcount=18
SaddleUp
Vancouver, WA
The same can be said for those that do buy it. I.E. Why would anyone spend so much money for a bolt on kit when it only takes a couple of hours or so to mount up a stock one instead and they will save not just a few dollars but rather will save several hundred dollars instead. Mine was a bit spendy because I bought a newer Super Duty unit and I still saved hundreds over the cost of the kits.
BroncoMark
Irvine CA
That setup on Ebay from West Coast Broncos is a relative good buy at $400 compared to other vendor's prices, but I'm a do it yourself kinda guy. I can build the same setup for half that and the satisfaction of saving $200 AND saying that I fabbed it myself is so worth it.
On the other hand, if I had an unlimited budget, I'd just throw down the credit card and my bronco would have been built years ago.
Mark
Bronco Klutz
NW Indiana
BroncoMark said:
That setup on Ebay from Wild Horses is a relative good buy at $400 compared to other vendor's prices, .
That's NOT from Wild Horses.
Wild Horses uses a good H-boost unit with an external accumulator.
BroncoMark
Irvine CA
Sorry, my bad. I meant West Coast Broncos. When i started typing the "W" my mind must have instinctively typed the rest. The Duff units are also internal accumulator.
SaddleUp
Vancouver, WA
If I were to buy a kit I would spend the extra $45 for the Wild Horses setup. I can buy a Hydroboost unit for a late 70's Lincoln though for $50 and then another $50 to $75 for high quality Aeroquip lines and fittings which saves $300 or so over either one. As far as throwing money at it I wouldn't do so even if I did have an unlimited budget. There is a big advantage to doing as much as possible yourself. I.E. You become more intimately aware of what parts, etc. go into putting the various modifications together which makes you better prepared to deal with it if something breaks.
swa0330
Portland,OR
Okay, here is what I know. Miley worked with the guy at Hydratech to create the hydroboost system that all the vendors are now selling for $700 or more dollars. Seeing as how he and I were parts hunting together a week and a half ago, I had ample opportunity to compare my $15.46 01 Chevy Astro Hydroboost setup to this
http://www.wildhorses4x4.com/hydro.asp
What I bought for $15.46 is the exact same unit that cost $445. It is so DAM simple to do a hydroboost setup for yourself that anyone who pays $700 is a little bit lazy in my opinion. Why even buy an EB if you just want to bolt everything on. That's what Jeeps are for. Sell your EB and get a Heep and hang a Barbie in the mirror while you are at it.
I couldn't agree with SaddleUp more about knowing your bronco. If it breaks, I know how to fix it. There ain't AAA in the middle of the toughest trails out there. Sorry to sound crabby, and I am not saying this to anyone specific. Just wish some EB people out there would be willing to listen to those who have done the work, because the savings could be tremendous.
swa0330
Portland,OR
Furthermore, the one thing that I failed to mention. IF you are driving a hydroboosted bronco off road and your engine dies, so do your brakes. So to everyone out there who is all about the hype of hydroboost, make sure you have a dialed motor for offroading or you'll be kissing a tree every now and then.
swa0330
Portland,OR
Here is a photo
broncoswede61
Los Angeles,CA
This might be a dumb question....If the engine dies do the brakes still work like manual brakes?
Mark
Bronco Klutz
NW Indiana
That's what an accumulator on hydroboost is for. You get a couple extra pumps with power when (if) the engine dies - then it falls to manual brakes.
Your not totally without brakes.
72Sport
The hydroboost is just a hydraulic assist for your master cylinder. No hydraulic pressure you are back to manual. Actually there seems to be a spring or two inside the booster I have so you may have a couple of pounds of spring force to over come which you wouldn't have if you had no booster.
If your master cylinder has a large bore the more leg pressure to required to stop when the engine dies or your assist goes away for what ever reason. Be careful when you size your master cylinder some day you might lose the assist and have a big problem stopping. The smaller the bore on the master cylinder the less pedal pressure required to stop and the more sensitive the brakes become with hydroboost. Some hydroboost units give more boost than others according to the experts. I don't claim to be an expert but I have been doing a bit of reading on this site and everywhere else. You might call me a Newby.
SaddleUp
Vancouver, WA
I don't know where your getting this from. If my motor dies then I get about 3 times using it where I have full power assist from the booster via the accumulator. Then once it's bled down I effectively have manual brakes which is much better than using a vacuum booster where you will have to fight the diaghram in it to stop. Not sure on the springs mentioned above but in testing I can't tell the difference between the hyrdoboost brakes after they have bled down and manual brakes. If there are springs there then it isn't enough to make a noticeable difference.
swa0330
Portland,OR
I guess I should be more clear. For those running a standard manual master cylinder, my observation is that it is far more difficult to stand on the brakes when the engine is not pushing fluid than just a manual MC. At least that's how I feel. I have to push the hell out of my brake pedal on my 05 Ram to get it to not roll out of the driveway before the engine starts if it is in neutral. Ultimately, I wouldn't give up a manual MC for hydroboost if I was running a carbeurated vehicle that stalled offroad a lot. Just me though.
