RKM
Ok I went to my fathers house to work on my rig. I figured out the emergency brake cables. I worked on the clutch assembly. I am still stumped on the fuel lines. I have all kinds of metal lines that I have no clue where the go or how they attach to the frame. I know some are fuel evaperator lines for emissions. I think I eliminated those. But I am not clear on what metal line goes where on the frame from the back of the rig to the front. I do have an aux tank.
Would any of you guys have a picture of the frame rail that showed these lines under the rig. It would be great to see it coming into the engine compartment to the fuel pump. I am not sure on the path it takes to get around everything.
I have an old ford build book that has 5 or 6 volumes it goes through the build of all the trucks and even the bronco. The diagrams in it are drawn and are not very clear. If I could get some pictures it would be O so helpful.
I am at the point that I may run a rubber fuel line for the time being, and maybe replace it with a braded one.
RKM
RKM
