I really really hate reinstalling doors!!
Sac '68 sport
Orangevale
This SUCKS!!!!
My door gaps were pretty good but the hinges were saggy so before paint I took off the doors and got the WH hinge bushing kit. I followed the instructions to the T and didn't notice that there was an error that had me drill one the part that needs to hold the pin still too big. Took them back to WH and they gave me another set to rebuild and a new kit. The new hinges are quite a bit thicker than the old ones so I had to make the hole a little bigger in the door and but I didn't test fit the doors back to the truck before paint which was stupid. The hinges are still sloppy even after the rebuild I can't for the life of me get my doors even close and I've chipped up the paint on the hinges an a few little spots on the doors where they were rubbing on the hinges. The drivers door is angled up from front to back by like 1/2 inch. It's like lambo. doors gone terribly wrong... I'm not sure I can space it enough to bring it back to normal. I can put all my 200 lbs on it and can't bring it down enough.
I did put a washer inside the door between the door and hinge on the single bolt to get it to angle the hinge back some. Might have to do another if it helps which I think it should. But I lost my help for tonight so I didn't get to try it.
How much spacer can you use under the hinges on the post side before the bolt heads hit each other and keep the door from closing?
Any other tips to get the top rear of the door to come down?
nosaj2k
Green River, WY
Man I feel your pain - been there done that. VERY FRUSTRATING. Unfortunately, I can't offer any suggestions - hopefully someone here can...?:?
Sac '68 sport
Sac '68 sport
Orangevale
Some sleep, a nice hot cup of tea, and a few deep breaths and my Dad and I went back in this morning and got them pretty good.
Really I just needed to vent a little.
BajaBronco
I hear you 100%. Takes alot of patience and is the hardest part of any of the restorations I do. Repro door hinges are thicker than any stock hinge, plus early hinges are thinner matieral than later ones. It's a real headache. Body mounts play big into the door fitment too. Glad you got it worked out....feel your pain.
Sac '68 sport
Sac '68 sport
Orangevale
And I got to start all over again by myself tonight when I got the guts in the door and latched them shut. Had to take out a set of washers on one side, and adjust the other a door just a little. Getting pretty good at it now actually. Probably have to adjust a little more tomorrow when I put the gaskets in (new in bag old stock. Score!!!). Those thicker later year hinges I got are causing some issues with hitting and rubbing on the passenger door though. I think I'll just take a little off the door edge with a file or dremel since the paint is gone there already anyway then touch the whole thing up with the little air gun or brush once things get settled out. Hinges will need to be resprayed anyway.
Never again will I paint a car with the doors off...
broncoitis
Ahh, the things we learn during these restorations! LOL! ;D I have the WH lift off door hinge kit and it needs to be adjusted as well.
I would love to hear if there are any experts with advice on lining up the doors and how to go about it.
Tito
CB Fire Starter
Bakersfield, CA
I feel you. Doors suck. And once you go away from the original hinges it's even more of a pain. Still trying to get the stainless ones to fit right on the wifes.
As was said, body mounts play a big role and all of it needs to get lined up and marked out before doing the paint or you will just hate yourself over and over again with the nicks and chips you will get on the fresh paint.
Washers are a help, thinner the better. The front fenders can be adjusted here and there to help with the front gap also.
It really is the biggest pain of a restoration. And anything you can do before paint will save you tears and grief in the long run.
broncoitis
So Tito, are you saying that it is best to just stick with the stock hinges? I still have those ready to paint. ;D
Tito
CB Fire Starter
Bakersfield, CA
Haha, depends on their condition, if the door drops down when you open it...time for a replace or a rebuild. I havent heard a ton of "good" experiences with the rebuild kits. If you use one of the aftermarket sets like Toms (better) or JBG (people have had to trim their doors to use these) or the stainless lift offs (bling bling) you just need to spend some time before throwing paint at it with the fitment. Dont wait till its all sprayed to install new hinges....bad idea, although we've all seemed to make that mistake already :-X
I wish there was a nice stainless non-lift off set offered. I only take the doors off the beast, the rest its totally unnecessary.
Good luck with it. I need to go out and do this myself as I will be spraying my new project soon as the weather gets consistent. I'll be installing the new ones from Toms.
JohnJohn
Richmond
Ah yes door alignment. I spent about 4 months on mine. Most of the time was spent walking away in anger and coming back to it with a fresh mind.
You may want to cover the door and the door opening with masking tape to protect the paint while you mess with alignment.
It also helps if your doors have the glass and guts removed because it is much lighter.
there are a few tricks and you may know these but I thought I would toss them out.
1. the hinge where it mounts in the door has some small adjustment and making the holes larger on the door may give you a bit more.
2. the door pillar face is at an angle so if you move the hinges further out the rear gap will widen and the front gap will shorten. Moving the top hinge out and the lower hinge in will jack the back of the door up and lower the front.
3. remove the striker while you are trying to get the gaps down
4. use shims as a last resort
5. you may be able to widen the pillar holes a bit to get more adjustment out of the nut plate but the bracket holding the nut plate in the pillar will limit how much.
6. like others have said, you can put washers under the body bushings to adjust the door openings on the tub.
good luck. take your time.
RV77
Springfield,IL
Hey Tito - I hate to hear that about the stainless hinges.Have you heard anything about WH's hinges ? I was thinking of getting a set not for the bling,rather a thicker and stronger hinge
Thanks Rick
Tito
CB Fire Starter
Bakersfield, CA
It's not that they are bad, I keep buying them but at almost 300 that's a lot to spend for an ok fitting product.
FWIW I just installed the new Toms hinges yesterday and they fit pretty damn good. Very happy with them. Wish they were stainless too so I didn't have to paint them but you can't win em all ;-)
BajaBronco
Thanks for the toms hinge report- I'll try those next. I hear the talk of WH's thicker stronger hinge... Stock hinges are not weak or prone to break off... Wonder why they made them so much bigger when "stick thickness would have been fine. Stronger is great, but only where needed. Seat springs, shock mounts...etc.
