- Jun 4, 2002
- 35,061
Was under the Bronco looking for the best way to mount up the rear ABS sensor (another story for another day if it even works) when I started looking at everything else.
Found the monster motor mounts don’t do much good unless there are bolts attaching them to the block. One was missing, another about ready to come out. That was on the drivers side mount.
Then took a peak at the exhaust, tightened up a few nuts there.
Removed the gas tank retaining strap and straightened it. Still need to make a skidplate for that.
Added a few more zip ties to keep things as nice as possible.
Put a grease zerk back into the front driveshaft to replace the one I shaved off back in November.
Good news is the transfer case doesn’t have any leaks still and the new fuel filter is still clean.
I also finished modifying the offroad lights and got them installed, but the final wiring still needs work. Right now the switching is done with a quickly rigged speaker wire coming off the relay into the cab and an alligator clip. I just had to make sure they worked. Now to find a switch that I like and do the final installation.
The bummer was when I went to reinstall the steering stabilizer that broke off back in December. The nut galled up on the stud and the stud broke off. Now I need to go out and get a new stabilizer.
I should go find the grease gun and do some of that service work as work as well, maybe even put that quart of oil in it to top it off too.
