If you rolled yours over
Casey835
to paint the bottom, how did you do it? Or suggestions on how to paint the underside of tub. I was gonna stand it up on the rear and spray the bottom of bed and floor pans.
martinphoto
Stood mine up on end leaning against back of my garage for over a month as I sand blasted, patched a few rust spots and then painted. I built a frame out of 2x2 tubing to replace the tailgate and supports off of that to keep rigidity in the rest of the body.
jim3326
Appleturkey
I didn't blast or paint mine but I rolled it on it's side to do some patchwork.
Jim W.
J-man
Holladay, UT
Man I wouldn't of even considered rolling my tub onto it's side, so I simply built a rotisserie and wow did that work perfect.
Broncitis
MEB Founder
Auto Twirler and before we had that, I used a forklift and some frame adapters I made to pressure wash under one when I started on it.
Having the right tool for the job makes it much easier!
jim3326
Appleturkey
It wasn't rolled, it was set on it's side and the only body panel on the ground was the lower rear quarter panel. Clean concrete no problem. It was all getting repainted anyway.
Jim W.
