Ignition Hole?
broncoitis
Is this what the Ignition hole in the dash looks like? Just need to know for sure so that I can draw it in CAD and add it to a Dash Panel for my custom dash. It will be cut out with a Laser or Water Jet CNC so easier and better overall result to add it now then to weld it in later. I have attached a pic of the hole that I am talking about.
On another note, does anybody have an extra Ignition Cup and Bezel to mount the switch to the Dash? I have the switch and tumbler. Don't know what happened to the other pieces. :(
broncoitis
broncoitis
I also started another thread about this in the chat forum and got good responses as to the location of the hole but more specifically I need to know what the hole looks like to mount the ignition switch to. Sorry for the double post on this subject fellow Bronco Nuts just need to confirm. ;D
broncoitis
broncoitis
Can NOBODY on this AWESOME site confirm that this is the cutout on the dash for the Ignition switch?????? %)
broncnaz
I probably coud verify it tomorrow I have a 67 dash panel in my shed. But it does look correct to me.
broncoitis
broncoitis
If you could verify, that would be GRRRRRREAT! I think that it is correct as well but this cutout was already cut off an old dash and I cannot verify by the location of the hole. ;D
That looks right, but I don't have a dash apart to actually confirm it.
If the shop is really cool about it, take the switch with you and ask them to cut a test hole in a piece of scrap first. Do a quick test fit and if all is good then green light the cut of the whole dash. You can test fit in a few seconds while they are clamping down and setting up the cut for the whole dash.
broncnaz
Heres a few pics of the igintion hole from a 67 dash.
jalapeño
Philly 'burbs, PA
Yep; that's it. I just cut a whole then notched out the 5 sections with a small file. 3 notches are for the rear cup & the other 2 are for the bezel.
