Ignition switch dash mounting???
ric9469
Orinda, CA
Well, like a knucklehead I lost the key to my Bronco so I went a bought replacement from the local parts place. It was listed as stock for a '77 Bronco. Well it matches what was in the repair manual but not what was in my Bronco. I'm assuming the one that was installed was a Centech part (Centech wiring harness). The Centech ignition had a normal screw on retaining bezel the "stock" does not. It has two little posts and it fits thru the hole in the dash but I have no way of securing it to the dashboard. Any ideas on how to secure it or where I can find the stock mounting pieces. Getting tired of having to hold the switch while I turn the key. The one I bought looks like this. I did have to cut the connector and figure out the wiring (probably not right but it works).
Broncology
You will need a bezel to secure it to the dash as mentioned previous. Although you many find out that the new spring you have on that new ignition is to tall. When i did mine the spring was to tall/long not allowing me to lock it to the bezel. It took me a couple of hours to figure out what the problem was...it was a pain. If you still have the old ignition and spring , take the new one off and put the old spring on the new igintion. THis is finally what i did......firt attempt to put it on and it fit. Putting those stupid bezels on really sucks.;D
ric9469
ric9469
Orinda, CA
Thanks guys. Found the bezel and "cup". Wish I'd done more research before I cut the wiring harness for the new switch, could of just got an adaptor. Oh well, live and learn.
