Ignition Switch Shorting on Dash
shinyisme
I replaced my ignition switch on my '69 and before replacing it back in the dash (dangling by the pedals) I did a test start with no issues. Killed the engine and went to install the switch behind the dash, forgetting to disconnect the battery, bright flash from the ignition spacer making contact with the dash and my 70 amp maxi fuse blew. New fuse, battery reconnected, and ignition switch installed in the dash cranks right up. ~5 starts later, luckily it was in the evening or I wouldn't have seen it, another flash from my ignition switch and a fried maxi fuse.
Right now my short term fix has been to drive my bronco around with the ignition switch dangling under the dash by my pedals. I've done some initial research and it seems to be either bad switch (brand new, but not unheard of) or the center post is shorting on something. I'm just confused on how it's shorting through the spacer and wanted to see if anyone had a similar issue before I started putting money into new parts.
#11 on this site?? anyone had this problem
http://www.mustangandfords.com/how-to/interior-electrical/1511-dont-do-it-top-12-wiring-mistakes/
specs
original 302
Pertronix ignition system (MSD is dead to me)
Painless Harness
Optima Battery
New Maxi Fuse is 50 Amps
Twidgeon
I'd go back and check all my wiring connection are correct. Also, I believe your ignitions body is the ground through your dash. If your ignition isn't installed tightly in your dash you might get some sparks if it loses it's ground connection by jumping around.
1strodeo
Squirrel Watcher
Wisconsin
X2 on what Twidgeon said, disconnect the battery and install the switch in the dash and go from there. Until then it is not properly grounded.
SteveL
Huge chevy guy
Hawthorne ca
I don't remember if it was my ignition or headlight switch but I had shorting issues after installing a centech harness. I called centech and they said check where the switch plugs in to the harness. It's common for a blade to miss the slot it plugs into. Sure enough that was it. Also centech sent out everything that was damaged free switch and all.
nickgp
I had a bad brand new one. With what you've said, I would try another switch.
Viperwolf1
electron whisperer
specs
original 302
Painless Harness
Optima Battery
Make sure you don't have the wrong wire connected to the proof terminal on the switch. That one goes to ground in the crank position and should only have the purple brake warning light wire on it.
Hey Shinyisme, welcome to classicbroncos.
The ignition switch does not need to be grounded except for the brake warning light. No other circuits on that switch should have any connection to ground through the switch to the dash.
So yeah, check those connections under the cap and make sure nothing is off. If that checks out, look around at the adjacent wires and connections to see if anything else got jumbled around.
If the only thing you replaced at this time was the switch, and all the other stuff checks out, I would get another one. Don't think I've ever heard of this issue with a switch, but with the huge number of defective parts right out of the box these days, I would not rule it out either.
What harness are you running? A recent re-wire, or been in for awhile?
With 5 good starts before the last short, it's still sounding like a switch or loose/bad connection.
Blowing the full 70 amp main fuse is a big deal. I'm wondering if it's the main power wire into the switch? Yellow originally, but Red in many aftermarket harnesses.
Depending on which harness you have, that circuit may go directly to the fuse box first, or might branch off to the switch first. So back to which harness is installed.
Good luck.
S
shinyisme
Thanks y'all
Thanks all!!! So I went ahead and got a new ignition switch off amazon. When I swapped the old one out I noticed the center post nut holding wire #932 was pretty loose... so that could have been it OR I remembered that I had to modify the diamond plating covering the dash to fit the ignition switch and metal shavings could have fallen into the old switch. I've done ~20 starts with no issues, but I still carry around a needle to get the tumbler out, 1/2" wrench to disconnect the battery, and plenty of spare fuses.
To answer some previous posts; I installed the painless wiring harness early 2016 chose them over Centech purely because painless is from the world's greatest state TX. Ran perfect for ~6 months until I was getting some ignition problems due to MSD's ignition coils being crap and that's when I ran into the ignition switch shorting out because I wanted my keys to match and a new bezel.
Here is a wiring diagram from painless and it is exactly what I did minus bypassing the neutral safety.
