________________________________________
1968 Bronco with new Painless wiring.
Starts and runs well for a dozen + or so starts.
Next time I start it, the 70 amp painless maxifuse is blown.
So I jump the fuse and it starts and runs fine.
I shut it off and start it again just fine.
After I let it get hot, I shut it off and smoke starts rising from the back of the dash board and I hear crackling...turns out the yellow wire from the back of the ignition switch is REALLY hot and the connector melted to the blade terminal on the ignition switch.
I replaced battery terminals connectors and cleaned the terminals.
Replaced the voltage regulator (external)
Put a new 70amp maxifuse in and start it just fine.
Turn it off and try and restart but the 70amp fuse is blown again.
Why am I blowing this 70A maxifuse ?
and if I jump this fuse I run the risk of melting the ignition switch.
Do I have an ignition switch problem or something else?
Is there any way to test.?
HELP..
FRANK
HELP..
FRANK
