I'm an idiot
weasel
Norfolk
So for the longest time (4yrs or longer) I had this front end vibration that I thought was bad tires. Then I thought it was new tires need to be rebalanced again. Then maybe death wobble or ball joint and tie rods. Non of the above was the issue. ?:?
Well I came back from a 14 month deployment and moved to VA. Still had the same front end vibration. About 7 years ago I had the J shift dana 20 changed to a twin stick. Maybe your getting were I'm going here. I've been driving around with the front drive shaft still engaded in 4 hi. :eek: No wonder I get a vibration when travel 60 to 70 mph on the highway. :eek:
Hope I dint fudge up something. Luckly I would only drive for short distances and maybe put 2000 miles on the old girl.
asinor
Tulsa, OK
Mine stays in 4hi with the hubs unlocked. If it's vibrating that bad there is a problem with the shaft or joints.
AZ73
You never tested it when you put the sticks in?
Apogee
Tangent, OR
Bronco's have four wheel drive?!?! Saweet! Learn something new everyday. No harm, no foul...carry on.
orangecrush4u
Shelter Island, NY
Shhhh don't feel bad all present day trucks are locked.
BRONCOBERT
If you want to know if your 4WD is engage or not get under the truck and see if you can turn the front drive shaft by hand or not.
ugly74
Bronco abuser
Colorado
Yu have a problem with the front shaft, then. Ive left mine in 4, with the hubs locked and everything, and did 80+ with no problems. Not the best of ideas, but it shouldnt hurt it.
Believe me, ive done far dumber things than that so dont feel too bad....(dumbass!:D)
Pa PITT
Stephenville TEXAS
Weasel .. No foul I'm going to say we've all done that. I've had a Big Bronco 1st it was a 1980 I got it in 1986 I used to farm a lot more and would head into town not remembering, that I had the hubs locked into 4x4 I'd feel the vibration and slow down to under 50 or get out and unhook.
.. Now I've done this a few times with the little 72 Bronco But I just stay on the farm mostly now .. So I only take mine out of 4x4 about 3 times a year.
... Yes there is a vibration most of the time.
.. I'm just kind of glad to find out that I'm not the only one ......
xcntrk
NOVA
Why do some of you guys leave the front engaged with the hubs unlocked? I don't understand what you're gaining there. You still have to get out to lock the hubs to get in 4-wheel. All I see are downsides... more drivetrain power loss, worse fuel economy, front end wear & tear, etc...
Now if you had auto locking hubs I could see where this would be a huge benefit!
GRN_MEANIE
Now that you have twin sticks wait till you have the front in low and put the rear in high. Or the rear in neutral going down hill... Rear brakes will lock up and slide. Or the rear pops out on a snow run and you can't figure out why your truck sucks!
Mark in Memphis
... and you can't figure out why your truck sucks!
I had a similar thing happen to me on a trail ride right after I got my twin sticks. I couldn't figure out why my buddy was driving right out of the holes and I was struggling. Finally, he told me my front tires weren't spinning. One shift later and it was a "FIXED"!
BluebroncoNC
Asheville, NC
Welcome to this board full of idiocy.... I yanked my tranny and D-20 because, and I'm only admitting this here and not on my build thread, I didn't know how to shift my D-20 properly and thought there was something wrong.
While it was all yanked down, I went ahead and spent $800.00 on a rebuild for the tranny... And learned how to shift the D-20 properly while on my work bench. Expensive learning lesson.
Like I said, welcome aboard.
jim3326
Appleturkey
Don't beat yourself up too bad, I was flat towing mine down the hiway and thought the transfer case was in neutral when it was in 2 lo. Wondered why the milage went to s*%t in a handbasket%)
Jim W.
asinor
Tulsa, OK
I leave mine in 4 high because getting my t shift in 2 high takes an act of God while you hold your mouth just right. It's no/low power loss with unlocked hubs.
Sent from my SGH-T989 using Tapatalk 2
