I wasn't happy with my Optima dual battery setup cabling. I had positive cables going to both the top post and the side post on the auxiliary battery, mostly to address the crossover to the primary battery and the winch, but also some accessories like the air compressor and six shooter.
As it happened I felt that the side post exposed terminals were dangerously close to the wild horses optima battery tray. I know the battery is held securely but I still didn't like the clearance.
The negative side was / is no problem as it is going to a chassis ground, so there's only one connection to each Optima negative.
I ordered this terminal block on Amazon and I think it's going to work out great. It cleans up the connections nicely. All I believe I need now is a rubber sheet on the driver side inner fender well to provide some additional protection for the positive terminal.
