I’m in the process of doing a bunch of new wiring to support an EFI harness. While I have the dash out and am running new leads to the engine bay, I’m thinking ahead and may want to run some wires for an in-cab dash mounted winch control. I currently use a bank of carling switches with etched rockers. I would add the winch control to this existing bank which is dash mounted within reach of the driver seat. I would use a momentary ON/OFF/ON switch body to command the IN/OUT from the winch control.
The question; is a dash mounted winch control possible and practical? I don’t currently have a winch and can’t speak from experience. I can only imagine hooking up the wired remote and running through to the interior is a PITA while wheeling off-road. But at the same time, holding down a momentary button on the dash while trying to control throttle & steering to get unstuck sounds equally as challenging.
Sooooo I’m looking for input from those experienced with winch control as to if a dash mounted switch would be beneficial.
![WN1IO-01.jpg](https://otrattw.net/images/P/WN1IO-01.jpg)
