My turn indicators recently stopped working. After reading several threads here, I checked to see if my hazards would still work. They seemed to start then fade, almost like they were running out of juice, then they completely stopped. I found that the fuses were blown, and I replaced them both. Still nothing, so I replaced the flasher. Still nothing, and I found the fuses blown again. Then, I found that if my hazards are pulled "on" (they don't activate) and I push the brake pedal, my front indicators come on steady (brake lights do to, as they should). Release the brake, they go out. Press the brakes and push the hazard button back in, they go out. The non-functioning indicators and hazards is a new problem. I don't know if I had the weird brakes w/ hazard equals front indicators on problem before, since I'd never used the hazards while braking.
So, any suggestions of what to look at? I'm not knowledgeable enough to run down a short on my own. Anything else from those symptoms?
Thanks for any thoughts.
Ruby
Ruby
