So I have a new tube bender, tube and a bunch of crazy with as much time on my hands. Found these on another thread. Love the idea. Have already cut up the radiator support and moved rad section out toward the inner grill as much as possible. Inner fenders need to be cut as I want to add extended length shocks for my new full width axles. (3.5 Duff lift). Want to tie in the outer fenders, rad, and coil and shock mounts. However, I fear body squeak because if I attach to the frame it will make more rigid, thusly canceling the poly body bushings. Thoughts??
What about mounting radiator tube mounts to the body mounts and possible a rubber pad/isolater where I want to run the fender tubes up to the cowl???
Any thoughts are appreciated.
