Inner fender, kick panel, door post post
Lunar-tic
Brentsville
My attempt at fixing the rust problem. Hopefully it works out.
Lunar-tic
Lunar-tic
Brentsville
The floor pans were a hot mess, I wish I had a before photo. The PO had a combination of fiberglass/bondo/spot welded sheet metal over/under the rust. Nothing no one else here hasn't seen, but it was funny the more I melted off with the heat gun the worse it appeared. I don't think the passenger side door post is as bad, at least I sure hope not. I'll keep posting pictures for the other rookies out there.
Toddpole
Definitely a case of a silk purse/sow's ear. The rest of the Bronco looks really nice. Kinda funny, in a sad sorta way, that the PO tried to hide the problem rather than cure it. Good luck! Looks like you have the hard part whipped. Nice shop floor, btw!
Lunar-tic
Lunar-tic
Brentsville
I got the flooring in rolls from Costco, it is nice, but doesn't tolerate the slag from flux core welding. I had a small fire fixing some of the corners of the floor, lesson learned, I bought a welding blanket. LOL
smokinjoe
New Braunfels, TX
Looking like a great start!
Who's pans are those, which vendor? I have just about the same cancer as you and I like those lips on the pans.
Ironically, my PO also tried glassing the rust spots.
Lunar-tic
Lunar-tic
Brentsville
So far all my metal has come from Jeff's. The floor pans are decent, I'll let you know about the rest (door post, rocker, kick panel, inner fender) as I work through replacing those.
jonmelton
I was in the same spot about 8 weeks ago. I only replaced the floor pans, but should have replaced rockers and inner fenders. That will be later.
I used Wild Horse's drivers side pan and it was beautiful! On the passenger side, I bought TBP because I liked how big the piece was. I wish I would have bought the two Wild Horse pieces...
I learned a lot about welding, made a lot of mistakes, but had fun.
Good luck! Don't forget the floor bracket under the passenger seat like I did. It was completely rusted out of the frame so I had to improvise and build my own.
Newbie Floor Pan Removal
Lunar-tic
Lunar-tic
Brentsville
Luckily all my floor braces are in good shape. I am going to POR all of that stuff before the final welds. I bought a Hobart Handler 140 and using it as an actual MIG (instead of flux core) it is a dream. I'll post some pictures of this weekends work in a few. Mostly good progress, but I did find some unexpected rust in the driver's side cowl. That should be a treat to fix.
Lunar-tic
Lunar-tic
Brentsville
Here are some pics of what I was able to accomplish this weekend.
WheelHorse
Looking good!
What have you found to be the most difficult part of the removal process?
What would you do/advise to do differently?
Lunar-tic
Lunar-tic
Brentsville
Drilling out the spot welds are the biggest pain for me. I can never seem to locate them all. I recommend buying several of those bits. The rest was just me taking my time and reading threads here, a lot of reading and researching goes a long ways.
enthusiast1977
William,
these are great pictures. I have been following this thread and it looks like you are doing a great job. I am getting ready to tackle this same thing so it really helps me out with all your great pictures. thank you.
Lunar-tic
Lunar-tic
Brentsville
The more I dig the more I find.
Lunar-tic
Lunar-tic
Brentsville
Slowly inching forward with this. Welding old sheet metal is a PITA, I don't care how fancy your MIG/TIG is. Here's a couple of before and after shots of my first repair. I did work on it a bit more after I took the "after" photo. The spots with the magic marker needed a bit more attention. I hope to dig into it heavily this weekend.
Bferrari
Looks good! Keep plugging along and you'll be there before you know it!
Lunar-tic
Lunar-tic
Brentsville
Made a little more progress over the weekend. Started mocking things up. I still need to paint everything and repair a couple more minor rust spots, but it actually looks like I accomplished something.
spray1963
Boca Raton,FL
How did the Door post from Jeff's fit? I have now bought TBP and Dennis Carpenter posts and both are nowhere near being a good fit. I have a body shop doing the sheet metal work and they are having issues making it work.
Thanks,
Scott
