Bronco
I'm trying to figure out why my gas gauge, temp gauge, and oil pressure gauge are not working. It seemed simple enough, put in a new IVR. So I bought one at Napa the other day expecting that to fix the problem, but that did not work.
When I first had this problem the gas gauge and temp gauge would read on the completely low side, while the oil pressure gauge would read past the high point. After I put the new IVR in they are all just staying at the low end now. I don't know if this means anything or not.
All of the lights on the cluster work. I tried checking all the grounds I could find. I know absolutely nothing about electrical so I may have missed an obvious ground.
There is power coming to the IVR. I hooked up an analog voltage meter on the output of the IVR and I was getting 10 every once in a while. It wasn't really steady on where it would end up. It would end up anywhere between 4 and 10. It bounced every half second or so.
I'm thinking I will try and put another IVR and see if that solves it. But wanted to see if anybody had any other trouble shooting tricks I could try before Napa makes me bend over again for a $60 IVR.
Thanks for your help. This is on a '76.
Aaron
Aaron
