Are you planning on just the main tank or are you using the aux. tank also?
BCB web site has a diagram in their tech section for using two tanks with a external pump. It requires a supply pump as well.
If you are running just the main tank, the internal will work just fine. They are a pain to replace when they fail.
The Ford trucks use a pusher pump in each tank and a main pump on the frame rail.
I am in the planning stages of the same conversion. I think I will use BCB's idea.
