International Scout
rydog1130
I know this off topic but...my grandpa help design the international scout and theres one about a mile from my house. Im thinking about making an offer on it because I want to restore it in honor of my late grandfather and have it in the fam. I think it's cool and I think he would think its cool too! Anyone know of any forums like this one or stores that sell after market parts, what i should offer, etc? i have no idea if it runs any info would be great!
broncodriver99
Glen Allen, VA
There are a couple of forums dedicated to the Scout and Scout II. Binder planet is one but there are a couple others too. There are a few specialty vendors for Scouts just like we have for Broncos, the forums will lead in the right direction for those. I see that guy has an old Waggy as well. Must be an old school 4wd guy. That scout looks decent but they are prone to rust just like Broncos, probably more so. Go over it with a fine tooth comb. Scouts don't have nearly the aftermarket sheet metal support that the Broncos do so buying a solid rig is key.
tirewater
San Francisco Bay Area
I think a Scout would be an excellent vehicle.
The nice thing is that the price range for the Scout is fairly compressed. Meaning that a semi decent Scout will only be a couple of grand more expensive than a derelict.
http://sfbay.craigslist.org/search/...a=102&nearbyArea=12&nearbyArea=97&query=scout
If you really want a Scout, there's plenty in the non-rust belt areas to choose from. My advice is to look for one in the SW and transport it back.
lowbush
Summerland Key, FL
That's an early one,61-62 my guess. I had a 62 way back with a 289.
Yep looks like an 80 they made the 800 which was the 80 with a v6 option IIRC then the scout 2 I had a 2 but always liked the lines of the 80 better. Plan on doing an engine swap and gears as it will most likely have a 4 cylinder in it.
rydog1130
rydog1130
Many of em are Chevy
powered to the cost and availability of the international stuff
Are the swaps pretty easy? If I found a decent small block chevy and auto trans would I run into any major headaches? Did these ever have column shift or would I need to do a floor mount? Probbly questions more suited for their forums but cant hurt to ask here
sykanr0ng
No V6's in Scouts that I know of. Scout II's had an AMC 258 option in some years. 80's & 800's were 4's or 8's only AFAIK, with the 4 being one bank only of a V8.
A friend's 80 build: http://www.expeditionportal.com/forum/threads/120624-All-Purpose-Scout-80-build
You're right about that.
Some people get confused by IH having a 304 engine and think it was an AMC engine, the only AMC engine IH used in Scouts was the 258 I6. (probably their best engine ever)
The 4 cyl. 152 was half of a 304 V8
The 4 cyl. 196 was half of a 392 V8
sykanr0ng
IH V8's like the rest of their engines are heavy-duty.
They are not built for maximum performance but long life at near 100% duty.
If you imagine a diesel engine but running on gasoline you will see an IH engine.
Like all heavy truck parts they are expensive, but that is because they are built to last.
The nickname for IH is It's Heavy.
lowbush
Summerland Key, FL
I meant straight 6 but wrote V, but apparently it was a Scout 2 thing. I could have swore that was an option in the 800. I thought all the 2's where V8's or the Nissan diesel. It's been a while since I owned my Scout so my memory is fading.
Techstudent
Missoula
I really like those early half-cab scouts. Almost bought a solid "barn find" last year but I had to be an adult about it. Wish I could have somehow managed it.
That one looks to need a fair bit of work but would really look great when done! :cool: I really don't know what they are worth. The one I was looking at was going for $2500 but I've seen some high asking prices on minty ones. I would venture a reasonable price on that one would be in the $800-$1500 range
rydog1130
rydog1130
i was thinking of throwing $500 at it and see if he'd take it
Pa PITT
Stephenville TEXAS
I'd go for it also since your grand father had a hand in it's .. Debut ..
& I'd say put a 4BT Cummins in it... The little Scout or ScoutII has a bigger engine compartment. So the BT Will fit mych easier than into our Broncos. & Even the cab of the Scout is just slightly larger than our Bronco. Both are pluses to the Scout.
