Interesting, so a Atlas or NP205 will bolt up to 4r70W? No adapter needed? What about frame mods, will either one fit between the frame rails?
What NP205 is the best for my application?
Thanks for the info, thats why I love this site!!!;D
Yes, either the Atlas II, NP205 (Ford version), or a STAK B box will bolt right up without any type of adapter and all will fit between the frame. Depending on your 4R70W you will need a 1" spacer for the Atlas, but the vendor I talked to included it in the price of the Atlas.
As for NP205 you would need one from a late 70's Ford truck or 78-79 Bronco. They came attached to both NP435 manual tranny's or C6's. Most I've seen have 1310 yokes (matches EB), those that have the bigger yokes can either be cheaply swapped or you can beef up your driveshafts with bigger yokes when you have them re-sized.
The downsides to the NP205 is that the low range is only 1.96:1 and the weight (135 lbs). I've found that when I get on a trail I drop it into 4L and "D" immediately and the engine and tranny run in an RPM range that keep things cool. With the 4R70W and lockers I've been able to drop it into "1" and slowly climb anything I've tried, but going down you have to get good at using the brakes without locking them up. I haven't done any super radical rock crawling, but have had no problems on 4 out of 5 rated trails. as for the weight it's similar to the STAK B box and just a little more than the Atlas II, but at least it came from the factory with a side mount to give it some frame support.
Look in my gallery for some pictures and do some searching. There are several members running NP205's.
