I've been slacking! :)
nvrstuk
PNW
I just realized that I didn't post this in the "what did you do to your Bronco today" forum and I'm too lazy to move it all over. lol
I have filled up dozens of times but haven't posted my latest.... 20 gal at a pop at almost $5/gal adds up. Here I'm at the rez and they don't have to pay $1.56/gal tax that our lovely little "give-away" State charges us. Paid over $6/gal several weeks ago. Diesel is oveer $7/gal all over town.
Started this tail light filler 8 yrs ago when I had time and since I opened up my exhaust with welded "kinda" pie cut 3" pipe instead of crimped 2 1/2" exhaust (from the mufflers back) and then installed a much needed TKRacing antisway bar so I can lower my psi on my ORI"s and get my pillow ride back.... I needed to finish this so I could see where my exhaust routed so I could install the filler neck. All stuff that's been on my "to-do" list for several (up to 8) yrs.
Inside the gas tank pic shows my 4 individual pickup tubes I put in 14yrs back. Was hundreds of dollars less than HydraMat when it had first come out.
Since my rear axle is moved back 6 1/2" and much larger rear homemade fenderwells are welded in, then the filler neck runs of out room to do this w/o spending days (literally) fitting & fitting.
  • 20260319_100800.mp4
    7.3 MB
Yeller
Rogers County Oklahoma
Looking great. It’s always good check stuff off, even if it’s slow and late. I think the pickups was a a wise move, water and hydramat = dysfunction. A few drops of water and it no longer functions correctly, learned the hard way, just a tiny bit of condensate in the tank…..
nvrstuk
nvrstuk
PNW
Good stuff to know! This means I can save major coin by not buying Hydramat but put in larger diameter lines & "T"s to make sure I pull enough fuel under heavy load. THANKS for the Hydramat/water info.
nvrstuk
nvrstuk
PNW
Let's just keep this a secret between you and me, Garry! :)
But I'll bet I have twenty hours into the hinge and the filler neck...
That's not counting the hinge assembly that I had as a non-functional filler location but the tail light was hinged as now I had to change the location of the hinge because of where my metal filler hose came up from my tank. No room.
kind of like the anti sway bar having eighth of an inch of clorence between my upper four length bars, my exhaust and my b hoop pillar support legs that come down to the frame...
toddz69
That's good to know about Hydramat - I had no idea.
Todd Z.
nvrstuk
nvrstuk
PNW
Me either TZ. I was going to call Holley because I read someplace on one of their sites that alluded to the fact that the average product life was only three years or so...
I was going to ask them why b4 I laid out cash to replace something that works great but limit my fuel tubing inlet diameter.
ssray
South Central NE
Brian...I had never run across it but was curious how it worked and what might be going on with water as Steve mentioned. It was described as having pores that close with no contact with liquid. Water has more surface tension than gasoline and so evidently stops up the pores and then leads to water in the fuel system. Another mentioned it as being equal to a 15 micron filter and maybe too fine for the inlet side of the fuel pump. I saw something about a 6 year life unless used offload in the dirt (sand 🤔) which could lead to shorter life and that I think was from Holley if I remember correctly. Somewhere it was mentioned that water was likely used for demos at shows due to not being allowed to use gasoline in those cases. Maybe misleading? With the cost and all the work if replacing every few years sure sounds sketchy. Supposedly works with any fuel with the exception of diesel.
nvrstuk
nvrstuk
PNW
Yeah, even if I have to replace it only every 5 yrs for me that's a no-go as what I have works great.
Even if I'm only pulling from one p/u screen that means I'm down to a gal of gas (like this am I figured I had 2 gal left in the tank as it took 20gal to fill) but that means to me if I'm that low I'm not doing any 20sec to 1 1/2min long pulls at full throttle till I put more in.
My fuel requirements can be pretty high at times so I'll "T" two lines & p/u's together to 3/8" & then "T" those to the other two... pumps like to push, not suck so I should be good.
Moving to a 455lph/pump soon.
ntsqd
heratic car camper
Upper SoKA
Friend of mine has a long, narrow increased capacity fuel tank under his '99 PSD. Apparently the tank was built with no baffles and locates the pick-up in the OEM spot, which places it near one end. We were discussing his options to deal with a low fuel level and an extreme fore/aft tilt. Hydromat was mentioned and then discarded as he thought that it wasn't compatible with diesel. I've no idea. Two pick-ups were discussed, but some method of automagically closing off the high pick-up so that the pump doesn't suck air is needed and neither of us was very comfortable with the ideas that we had. Makes me curious what people have tried and had work or not work and why it didn't.
nvrstuk
nvrstuk
PNW
Snowmobile fuel tank p/u's is what I used.
The mesh is fine & it blocks the screen enough when not submerged so the fuel is drawn thru whatever p/u is submerged.
It works.
You'd think the pump vacuum on the exposed screen would pull air thru the screen & render it useless but instead it still allows whichever submerged screen to allow fuel to be pulled thru it.
