I'm also interested in what you folks have experience with and used for spray painting.
I'm in the market for a new/used gun and I'm looking at a deal locally for an Iwata.
I have gotten away with decent paint jobs with cheap guns but I always hated the clean up in order to switch paints. Looking to get another spraygun for topcoat only.
I've sprayed with quite a few different guns. Some of them other painters I've worked with had and alot of them were demo guns the paint jobber would let me use for a day to a week. I tried an Iwata and didn't care for it and decided on a GTI from Devilbis. I have since retired that gun and it is now my 1K primer gun. I've learned to stick with SATA's but not everyone has the $ for them. SATA's are work horses, you can really abuse them and they will still spray great.
For what you are doing, if the deal is a good deal for the Iwata I say go ahead and get it. Compared to a non-HVLP siphon fed gun you were using you are going to be blown away. The new decent HVLP guns ($350 on up) will atomize the paint a whole lot better which is going to give you better transfer efficiency and a slicker paint job.
For the compressor.... Any spray gun will use the most air than any other tool you have so you need a good size compressor. A spray gun might not use the most cfm's than other tools but you are going to be spraying longer than those other tools and drain the compressor quicker. A spray gun has a higher cycle time I guess I'm trying to say.
A few tips for clean up....
1) As stated a liner system works great but they are expensive for a at home guy to use. Around $30 for the adapter, $30-40 for the liners, and $20 or so for the cups. I use 3M's PPS system and like it the best and it's the cheapest.
2) Get a Spray Nine bottle and fill it with laquer thinner. I don't know what they make them out of but the seals hold up to laquer thinner. The stream setting will make quick cleanup of the gun and cup.
