James Duff Vs. Wild Horses Power Steering Kit
pocketlock
https://dufftuff.com/product/power-...66-77-bronco/#optional-power-steering-bracket
https://www.wildhorses4x4.com/early-bronco-power-steering-conversion-kit
Looking at these 2 kits and trying to decide between them. Duffs is closer in terms of shipping speed. Any major differences in the pump/box performance that anybody can speak on? Most posts are from about 10 years ago when I was going my research, so I wanted to get some more current info. I currently have a manual steering shaft so I like the fact that WH comes with the shaft, but the Duff kit comes with a U joint to make what I have work in the meantime. Any suggestions? I'd love to buy a 4x4x2 box but not looking likely with my timetable. Thanks for any advice!
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Both kits use the same parts, so no difference in the boxes or pumps. Wildhorses includes around $400 worth of additional parts with the pulleys and lower shaft.
serial car restorer
Western Oregon
Both kits will require you to modify your existing steering shaft. The stock shaft is ¾" round stock, the u-joints with either kit will require you to cut to length and grind flats on the end to convert it to ¾"DD. Given that both will need that, I'd go with the WH kit.
P
pocketlock
Yeah, I already did something similar when i converted from the bell joint to the universal joint style steering connector.
