rmcbama
I purchased the front disc brake kit from JBG mainly because it has full coverage brake backing plate. Some others like WH just have a v-shaped caliper mounting bracket. After the figuring out which axle bolts, washers, and grinding, knuckle and backing plate grinding I finally got everything installed. With the new Warn premium hubs they looked great. However, it wasn't until after I installed the left wheel that I noticed the top part of the backing plate where the caliper mounts was bent upwards and rubs the wheel in a couple of locations when spinning. The right wheel has about 3/8 to 1/2 inch clearance in the same area. Comparing the two side the right side is parallel to the ground and the left side is bent upwards.
Anyone experience this? I can either try to bend this back down or get JBG to send another backing plate. Note that the bend is in the heavy part of the plate and mounts the caliper.
