Anyone using the slotted disc rotor from JBG?
When I went to press the studs through the rotor to assemble with the hub there was no interference fit.
It just slopped right in!
I guess the part of the stud that would normally wedge into the hub isn't long enough to reach it and it'll need to be a little thicker for the press fit into the rotor. Roght now with the stud just dropped in the threaded part starts just when it peaks out of the outer surface of the hub, so it would seem the length is okay.
http://classicbroncos.com/photos/showphoto.php/photo/9441/cat/6231
http://classicbroncos.com/photos/showphoto.php/photo/9442/cat/6230
I've got a call in to them but they need to get back with me later today. Figured I'd see if anyone here had run into this.
Thanks, -Rob
Thanks, -Rob
