Juiceman
- Sep 19, 2014
- 367
Read everything that I could find on the Kayline fast trac tops and the pillar mod. That being said, I haven't found anything with my particular problem. I am wondering if my vertical has already been cut. I have a space above the door in my mock up that looks like it will go away if I drill the pillar hole. If I do the mod, it looks like I would have to cut the flat vertical bar that the door closes against. Did others have to cut the flat as well to make the mod work? If I drill the pillar hole, it looks like the window frame of the top will fit nicely on the horizontal and the vertical would go the full length of the door window frame and sit in front of the door seal. Any suggestions?
