KBS Coatings deal. Rust Stops Here
NicksTrix
there's a great deal going on right now at KBS.
FREE shipping on orders over 75 dollars.
use code EB213.
these guys make great rust preventative products and coatings. their new cavity coater is really a neat process.
www.buykbs.com
this deal will only last till end of feb.
AZ73
Just got my cavity coater, but it wasn't $75. I used the code YT10 and got 10% off. I already coated the frame and purchased the supplies to do the underside and floors and got the free shipping earlier
asinor
Tulsa, OK
Thanks for the tip, I've been reading up on their products since the first time you mentioned it. Is the rust seal process a good option for the bottom side of the tub/wheel wells?
NicksTrix
NicksTrix
asinor. yes if you follow their step process it would work well for you.
like any refinishing process, better your prep- better your end result.
the rust seal paint is a excellent product. it and their top seal are both very chemical resistant. i love the toughness of it.
i prefer to get my paint in quarts from them. you have to be sure to totally clean the lips on the mating surfaces on the can tops. otherwise if it sits it will bond the top to the can and you kill it trying to reopen it if you can even get it to come apart. you have to have the cans sealed well otherwise it will harden and you will loose your remaining product.
