Large self tapping screws
CopperBronco
One of my self tapping screws fell out of my exhaust bracket… I didn’t get a good tap on the frame as it feels stripped, probably over did it.
I need a hair larger self tapping screw with flanged hex head… I can’t seem to find above 1/4” anywhere except in large bulk quantities. Any tips on where you guys buy specialty fasteners? Ideally online… I’ve tried Home Depot, Lowe’s, and Ace. Will try Tacoma screw on Monday… any tips much appreciated, seems like self tapping screws often max out at #14 or 1/4” in most stores, I need slightly larger. Next time I’ll be more careful and use some loctite as well.
C
CopperBronco
FYI I need a 5/16 x 1 1/2” self tapping screw with a flanged hex head or something comparable.
Speedrdr
Legend in my own mind
Paris, MS
I’d be tempted to just get a bolt/nut/washers, etc and be done with it. Just a cheap man’s thought. Lol
Randy
C
CopperBronco
Randy
That won’t work as it’s the screw that attaches the bracket to the frame, so no way to get a nut on it because it goes into the frame.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
5/16-18 rivnut
JSBX
Ebay has some 5/16 x 1 1/2 thread cutting bolts.
Steve83
C
CopperBronco
[/URL]
Shop for "tek" or "teks" screws to get more results like that. If this screw goes into the frame, I'd recommend something with a finer thread. This is too many:
[/URL]
Posting pics of the empty hole showing the location would make it easier for us to unnerstan what you need. I might have some (I used to be in metal building construction) lying around.
Thanks Steve, this is exactly what I’m looking for, but size 14 is the same size I have problems with… need 5/16 or size 16/18… do sizes even go that big or just switch to inches?
