Lars Bars Radius Arm dimensional Questions
ITSNOTAJEEP
ARIZONA
So I have gathered the postings related to construction of Lars Bars I could find on the interwebs. I didn't find any details on exact lengths and bend point. I did find the picture with a tape measure in it. I also know I'll need a 9 degree bend but I'd like to have a bit more details beforehand. Maybe one of you find guys or gals have additional info you can share?
70_Steve
Old Guy
PM me your email address. I have a word doc that is a collection of posts and pictures from Lars, describing the construction. I've never seen more information than this. Or... it was enough for me to make my own!
gddyap
Mtn View, CA
They are 6" longer. So the bend occurs where the stock arm would end then goes on for 6". The extended portion runs parallel to and directly under the frame. That's what the bend is for. If you didn't bend it, the extension would go past the frame towards the t-case or it would place stress on the radius arm bushings on the axle end because they would be pushing out.
Did you find the original "6 inches longer" thread on norcalbroncos.com?
gddyap
Mtn View, CA
Ask Lars. He designed it in SolidWorks (CAD software). He can send you a .pdf. I've seen a drawing. In the norcalbroncos thread, he and I discuss the slot width on the drawing being .240" and that .375" would have been better. In the end he used .375". We used his weld fixture so it wasn't critical to have a tight fitting slot to the arm web.
patrickk1
Cambridge
Originally I had planned on doing Lars Bars on my Bronco. After pricing out the parts, it didn't cost much more to do a full 3link.
ntsqd
heratic car camper
Upper SoKA
A 3 link is another level of difficulty beyond extended arms in getting the geometry right if you want good street manners. I'm not convinced the small gain is worth the increased effort.
I
ITSNOTAJEEP
ARIZONA
I am also building a fixture to ensure the arm is planar to the radius arm end. I have the fixture nearly completed but want to verify the frame joint and the arm end are where they need to be.
I
ITSNOTAJEEP
ARIZONA
Is Lars a member of Classic Broncos??
sykanr0ng
A group of the coloradoclassicbroncos.com guys got together and built a bunch of them for their Broncos, some of them are members here too.
You need to be a member to see pictures and other attachments there.
The attachments are too big to post here.
