The reason you see little to no wear in today's EFI motors is due to the use of low tension piston rings. This almost eliminates bore wear. I think you're confusing bore wear causes here. EFI's also suffer from mixture problems, as much as a carbed motor does. Run the cheap gas with no additives and it won't take long before you get wild variations in mixture due to dirty injectors. I've taken apart enough EFI motors to see this, some cylinders rich, some lean. The computer will enrichen the mix to try and compensate for the lean cylinders to the point where you get what you descibe happens in a carbed motor. I've seen plenty of EFI motors with excessively worn bearings too, something that can be attributed to thinned engine oil from too much fuel washing down from the cylinders. (in addition to many other causes of worn bearings) EFI is not perfect when it comes to keeping the fuel mixture "right".
