Just had someone install 5.5 leaf springs and coils for me. Couple things going on
1. He installed the Leafs backwards
2. Ride is really rough
3. When the bronco is in the air. The passenger side does not relax or move. Same amount of space between the fender and the tire as when the bronco is on the ground with all the weight.
4. I went from a stock leaf with 3 inch block that had pinion correction in it, to a 5.5 WH 11 pack leaf springs with no shim and now I'm getting vibration from the driveshaft and unusual squeaks that ive never heard before.
My question is - How do I fix this? Does it matter that the leafs are backwards? If the leafs are in the correct position will I still need a shim? Are the shackles too tight? Do I need to add a leaf shim to get the right pinion angle to resolve the vibration issues?
I know im all over the place.
