This on a '77 Don?
Or a swapped-in aftermarket tank maybe?
Got pics?
While I would be happy to sell you a new tank ;D, as I'm sure the other vendors would as well, make sure the leak is not just the o-ring under the sending unit.
If it's the seam, or other part of the actual tank, then yeah, it's patch-time or the perfect justification for the new tank.
But if it's just the sending unit seal, it could be $2 well spent. Well, 2 plus an envelope well spent anyway!
Here's what I'm talking about.
http://www.wildhorses4x4.com/product/Sending_Unit_Seal
Can you tell if that's where it's leaking? That's a stock type with a retaining ring that you turn like a 1/4 turn or so.
An aftermarket tank might not use the same setup.
