jimschulz
Want to see if anyone has a suggestion on a coolant leak I have on my 5.0 explorer motor. I had the same issue with the origional 302 that came out before the explorer swap. The water neck seems to leak ever so slightly from the water neck/thermostat housing. It doesn't leak alot just a seep. When it sits un started for a month or two during the winter there will be a pool of antifreeze on the timing cover. I have tried a different water neck, new gasket, RTV sealant and checked that bolts are tight. Has anyone had this issue with the 5.0/302 water neck? And if so, what were you able to do to stop it.
