OK Guys -
Here's the material list for reconditioning your calipers (this is for stock D44 Ford calipers, others you'll need to get the help of the counter guy)
- Auto Zone Part # 66781 Brake Caliper Kit - Front You'll need 2 of these, one for each side. It's an O ring and a dust boot. If you prefer O-Reilly's like I do, or Car Quest or where ever, the part # and/or description should cross over.
- Bleeder Screws - shouldn't be more than a couple dollars, you can upgrade to check valve 'Speed Bleeders' for a few dollars more. Make sure they fit, and are correct for your application. Look on the HELP! aisle, and also in the bins in the back.
- Some brake fluid. One bottle will be more than enough to do all of the calipers. We just need it for a little bit of assembly lube
- A can or two of Brake Cleaner. It's sure handy to have, and you'll need it for cleaning it up.
- A Scotch Brite pad, red or green. Your wife may very well have one for you under the sink for cleaning dishes.
I'll bring my wrenches and picks.
Go ahead and pull the caliper off remove the banjo bolt (don't lose the copper washers!) which will leave your caliper loose.
I used some compressed air and a blower nozzle to pop out the piston. Cover it with a rag (it's going to make a little bit of a mess) and give short, small bursts of air with the blower through the hole where the banjo bolt fastens to. The piston will start to push out, and will make a loud POP sound when it comes loose. It's startling, so be ready for it. This is when the mess will come (WEAR YOUR SAFETY GLASSESS!!!)
Once the piston's out, baggie it all up, and bring it to the meeting. We'll go over cleaning, and re-assmebly of it all.
If you're feeling really wacky, you can clean the caliper really, really good with some brake cleaner, and shoot it with a coat of paint in your favorite color.
Let me know if you have any questions, or run into any snags, otherwise I'll see y'all at the meeting!
Jason
817-480-9783
