LED tail light replacement?
Ksm
Quick question (hoping for a quick fix!)
I converted to LED lights a while back. My tail light is out. It's the flat panel of LEDs. So yes, it's not supposed to be burned out yet sooooo do I replace the panel or could it be a wiring issue? Just looking for some suggestions on where to start. I couldn't find any threads about replacing the burned out bulbs.....
Yeller
Rogers County Oklahoma
Its probably a bad ground. the load on LED's is very low so grounding is very important and can be hard to maintain. It could be internal but not very likely.
Ksm
Ksm
How do I go about fixing it?
chriskent85
check the socket with a volt meter to see if your getting power to the light, if not then its your wiring not the led.
Ksm
Ksm
I know a guy that would be happy to help, but I also know that doesn't help you learn. Bet he could stop and give some pointers;)
Sure! I even have a volt meter. It's one of a few things on my to do list before my Bronco gets abducted by an Oakie.
Ksm
Ksm
As long as I get to the LEBC Round Up on time I'll be good. With or without taillights. Although I haven't had the best luck lately....
