I think 33's are close to the limit with stock gearing, I have 33x12.50x15 and my gear 3:50. Your lift question has nothing to do with gearing, it's more for tire size.
Most folks say the sweet spot for 33" tires and a C-4 is 4.11 gearsSorry i meant to mention tire size.... currently i have a 5.5” lift (that is blocked up” in the rear) from previous owner. Stock gears, C4 automatic, I believe they are 3.5. It currently has 35’s tires on... it looks great but rides like a hunk of shit especially when you hit an incline. Im looking to improve drive ability and less wear and tear on drive train but still have a nice stance and decent sized tires. Not interested in changing gear ratio’s. I think the above post may have answered my question... that said what would lift kit would you guys recommend that absolutely improves driving and the ride? Thanks
If you want to improve drivability and less wear on the drivetrain and no interest in changing gears from a 3.50 I would say no bigger than a 31" tire.
I have been running 33 since I've owned my 74 and it has no problem with performance. I would not go any bigger than the 33 on it, but if he keeps his 5.5 inch lift 31 will look interesting;D , he could go with a 285/75/16 which is in-between a 31 and a 33.x2. Nothing larger than 31" tires if you are not willing to re-gear and worried about performance on hills.
Totally agree, I was thinking 4.10s or 4.56s, for use in the dunes. I have used the 74 up in the hills here in Washington, and its preformed very well.You'd have even better performance if you at least went to 4.10s. But some flatlanders can get away with taller gears.
But I can feel with lower gears the little 302 will probably happier ;D
