Lifting a 1974 Ford Bronco
I want to put a James Duff 3.5 suspension lift i was wondering if i would have problems with the axles and have to do lots of other stuff to the axles or stuff under there if i lift it that high. :)
OldieTwoShoes
Raleigh, NC
you will be fine, 3.5 isnt that much and it keeps most of the stock geometry functional, and i dont know what problems could arise from the axles..
Blue71
3.5 shouldn't hurt you. You may need to get a drop pitman arm for your steering and a drop track bar bracket for the track bar. This will keep your steering geometry in line. Make sure they give you the correct degree C-Bushings with the kit. I put a 3.5 on mine and it handles, rides, and flexes fine. Mine has components from Duff as well as other vendors.
Blue71
TJK74
Newark CA
The only other thing you might need to upgrade would be your drive shafts. By up grade I mean lengthen. They should be fine for street use but its something you should look into doing in the long run.
