Tonka7777
Need to move my extra 93 Ford Lightning GT40 351W lower aluminum intake manifold. The lower is the larger GT40 intake for a 351W. It was hot tanked and cleaned. Top is perfect, no cracks, all threads are good. On the underside, 1 of the cooling ports and the 2 sensor ports on the end has slight corrosion, but does not effect performance. A short weld would probably need to be laid down around the port and the mating surface milled in that area, so a good seal would be guaranteed. Pictures show the coolant and sensor ports on the lower. PM me if interested.
Thanks,
Jim
Thanks,
Jim
