[quote author=WyleCoyote link=board=5;threadid=8492;start=0#60852 date=1030652431]<br>[quote author=dpm77 link=board=5;threadid=8492;start=0#60849 date=1030652130]<br>speaking of lights, is this dim stealth mode with the headlamps normal? my headlamps give off this nice warm yellow glow, kind of like a flashlight just before the D batteries die. I mean<br>they work, but they ain't no halides. I put new sealed beams in, same thing. Is this just another of the endearing traits of my favorite rig?<br><br>Oh yes, and how do you change the turn signal dash lamps? left works, but the right died. Up behind the dash is the only place I havent stuck my hand, and with something this old....well you know...maybe I should just live with it, all the other gauges and lights work.<br><br><br>[/quote]<br><br>Turn signal indicator lights in the stock gauge cluster are not to hard to get to...if you just pull the whole thing out of the dash(Takes 4 screws, and some careful manipulating of the wires. Then you'll see there are several light sockets in the back(6 in all I think) they are the old twist out the plug, and the light bulb is in the plug. I had to replace all the bulbs in my dash when I first got it. You may also have to clean up the contacts with some emery cloth or a wire brush. Headlights dim sounds like either a grounding problem or corroded wire.<br>[/quote]<br><br>Thanks Wyle. corrosion is almost guaranteed, lord knows everything else is rusty. Ill chase the ground. What I worry about with the instrument cluster is that everything works now, with the exception of that one bulb, and I do not want to screw something up and have a headache on my hands. I guess all I can do is go slow and be careful. Thanks again<br><br>Dan
