I believe the 2V motorcraft is rated at 369CFM @ 3" Hg while the 4V is rated at 500 CFM @ 1.5" Hg. Here is one that will confuse most people, how do you get a 500 CFM carb to flow 750? Easy, test it with 2V pressure drop specs instead of 4V. carburators don't have a magical wall where they only flow so much. Flow is based on the pressure drop. 2V carburators are tested with a standard 3"HG drop between inlet and outlet. 4V 1.5"HG. But keep in mind that any vacuum in the manifold is a lack of pressure that could be filling the cylinders. If you look at the magazine carburator shootouts the bigger one is almost always the most powerful one. simply because it lets the most air in and does not create a pressure drop. But for most of us the drivability at less then max flow will trump the tiny flow gains on the upper top end. Too big and you loose velocity and the high velocity of smaller carburators is what makes them run good for drivability.
