Lincoln Hydroboost
josimps2
Does anyone know the size of the two fittings on a 77 Lincoln Hydroboost? I'm pretty sure that I have a Lincoln Hydroboost and I'm trying to get the fittings for it off of summit. Anyone know the thread size for this thing and where I could find these fittings?
Also, I've got a stock 77 Bronco with auto column shifter. Will this hydroboost work without an angled bracket?
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
If you have the Lincoln Master the hoses in the Bronco should couple straight up to the hydroboost unit. The unit I got out of a Mercury wagon (76 i believe) was the same. If they do not thread in look for a casting number on the hydroboost unit and send it to me. If you look really close to the unit and it is a Ford unit there will be a Ford oval mark on it. If it is a GM unit, it will have a 7 digit part number on it. If it is a Dodge unit, it will have a hyphenated number on it somewhere. AND if it has a 3 digit number on it it is a Bendix unit (motorhome) and usually starts with a 9.
Let me know which you have the Dodges and some of the motorhome units are bolt ons the GM needs adapters (lots of threads have the numbers, Ask Madgyver if you cant find them) The ford should be a straight connect UNLESS its the 4 wheel disc unit. That is another story
AS to the shifter the answer is YES. read the article called hydroboost brakes in the tech column there are pictures of a ford unit in my Bronco in the original location. You have to rotate the unit 180 degrees for it to work.
TOFIC
TOFIC
Redcliff Alberta
WELL,, did you get her done?? inquiring minds want to know.
Pictures would be nice, we all like shiny pictures.
TOFIC
josimps2
josimps2
TOFIC... sorry about the late reply... I don't want to upset the hydroboost guru. ;D Don't have a digital camera right now, but here is what I can tell you from the hydroboost itself. The following number is written in a pretty small font underneath one of the places a fitting goes in. D7LA 28559 AD 8081 It also has two other spots on the unit. One spot has 044 written on it larger than the previous numbers and then in another spot is has 2770 and underneath that it has 813 with a big letter H out beside these two numbers. I thought it was a Lincoln hydroboost but I can't remember I got it so long ago. It looks very similar to the Lincoln Hydroboost I've seen in post. I don't have any old lines for it nor do I have the master cylinder for it. What do I do?
TOFIC
Redcliff Alberta
you could never upset me on hydroboost!! so keep asking.!!
It is a 77 Ford hydroboost. As the only vehicle that had Hboost at that time was a Lincoln, your supposition is viable. It is a Bendix unit (813 is the giveaway here). There is a long chance it is a Mercury unit but that is usually seen only in Canada.
The lines are standard inverted flare, 3/8 and 5/16. simple brake line can plumb this puppy, like in the article. This is almost the exact same unit as the one in the article so anything I did in that article applies with yours.
AS to the master cylinder
If you are disk drum setup 77 Bronco works well
if you are all drums use your present master
If you are all disc 77 Lincoln with 4 wheel discs
What do you do?? Hook it up with what you have for brakes and REALLY get some serious stopping power!! You are about to get the brakes you have always wished you had.
As to the unit working after the long storage period I see no reason why it should not. If not, the seal kit is really inexpensive and easy to install.
Go for it and enjoy some serious stopping power and gain a little horsepower when you get rid of the vacuum brake booster.
TOFIC
