Lincoln PS Pump install
bronco_daddy
Paso Robles, CA
while collecting all my components for the ensuing HB install, I have concluded to just replace also the stock PS unit and use a dual return. Napa, etc all sell reman for under $60 and a pulley for another $30 and its a cheap date.
The question is this: the bracket that is factory, is it reusable with this pump http://www.napaonline.com/Search/Detail.aspx?A=NSP819157_0186448305&An=599001+101979+50040+2040002
I have searched and read all that I could but had not uncovered the needed information
Bob-
greatguy57078
There is a bracket that some guys use off an E350 Ford van I believe. I may be thinking of the Explorer serpentine setup that it works for?
This is what I will be using for the Lincoln Saginaw pump for my HB but I will be using the Explorer serpentine setup. Sorry if I misunderstood you. %)
