Linking a LUBR
JSmall
JSmall
Thanks for all the help in this thread so far. Here is a list of the parts I ordered to complete the rear 4-link. I'm not sure when I'll start, but when I do, I will keep you updated with my progress.
BanditBronco
That is a sweet spread sheet! Also a little more expensive than I would have anticipated. Hopefully the extra money is worth it and you won't have to modify to many brackets.
JSmall
JSmall
It is more expensive, but I think it will be a nice upgrade when done. It could also be done cheaper if different brackets were purchased and heims were used instead of Johnny Joints.
Digger556
It's looks like I'm too late to have an influence at this point, but did you consider doing a 3-link w/ torque arm? They tend to package better and separate the jobs of the individual links. (trailing links => fore/aft forces only, trackbar => lateral loads only, torque arm => drive/brake torque only) The advantage being you can run soft bushings on trailing links for ride quality and stiff bushings in the track bar for good handling. Bushings/cross-axis ball joints can be used in the torque arm to achieve different torque reaction characteristics.
With a 4-link, you have to compromise because longitudinal setback rates are directly tied to lateral rates. You can't soften fore/aft bushing rates for ride quality without losing cornering responsiveness. This is why OEMs always use a track bar on modern multi-link solid-axle suspensions.
I went this route with mine and would have no issues running this setup on a stock-height rig.
http://www.coloradoclassicbroncos.com/viewtopic.php?p=62941#p62941
JSmall
JSmall
Nice looking build!! I will have to defer to someone that understands what you wrote ;D This is new to me so I chose to go with the info that was out there when I was searching and the knowledge of the individuals posting in this thread.
Digger556
Thank you! It has been a long process.
I understand. The whole process can be overwhelming. Vehicle dynamics is a complicated beast with many trade-offs along the way. You need to have a clear picture of what you want the final product to be before you start. For most guys, it is an iterative process where you make small changes and adjustments along the way. If you read my build thread from the beginning, you would get an idea of the steps taken along the way.
Good luck with your build!:cool:
JSmall
JSmall
I have to say it again...you build thread is amazing! I thought my wiring was better than most, but yours is a different level of awesome. I will be picking your brain soon ;D
stryder94
Bring this back up lots of good info and got me thinking. I'm looking into building a custom frame about 5" wider, would that help with more triangulation for a rear 4link?
